Hi, I have a 2017 R-Line . I would like to fit a dashcam. Does anyone have an electrical diagram for the overhead console that shows where I can pick up a 12 switched live and ground?
You pick up the supply from the fuse board, behind the glove box, and run the cable up the A post and across under the headlining. Search the forum, there are quite a few helpful articles about the process. I fitted a pair of Nextbase (front and rear cameras) to mine and it was no big hassle (after doing the research).Hi, I have a 2017 R-Line . I would like to fit a dashcam. Does anyone have an electrical diagram for the overhead console that shows where I can pick up a 12 switched live and ground?
This should be all you need (though I don't think anyone has used the approach you're looking at)Hi, I have a 2017 R-Line . I would like to fit a dashcam. Does anyone have an electrical diagram for the overhead console that shows where I can pick up a 12 switched live and ground?
I fitted a rear view mirror dash cam with rear view dash camera took supply from fuse board . I would invest in a upholstery kit for prizing the lining out of way to run wires ,cheap off ebay but well worth itYou pick up the supply from the fuse board, behind the glove box, and run the cable up the A post and across under the headlining. Search the forum, there are quite a few helpful articles about the process. I fitted a pair of Nextbase (front and rear cameras) to mine and it was no big hassle (after doing the research).
