1 - 17 of 17 Posts
I know there are some of you on here who tow caravans..... have you had any probs attaching / putting your extension mirrors on. I tried today to see if they would fit as I noticed the mirror glass has very little gap to slide on and do up the lugs on the top mirror housing. So I tried to fasten on the bottom instead... again not enough gap and also on the bottom of the mirror housing (underneath) there is a thin rigid edge not flush with the mirror housing which protrudes. I have two sets the first set cheapies, but find them the best but the lugs too thick to fit top or bottom, & second set Milenco tried top & bottom, but would fit on the bottom of the housing but not the best by any means. Would welcome any feed back please....Thanks
Hi Stumpy
No problems with fitting Milenco mirror clamps on bottom of door mirror. I have never fitted them on top of mirror with this or previous Tiguan due to likelihood of scratching paintwork.
What I did invest in was a pair of emuk mirrors designed for the mk1 Tiguan. Absolutely the best mirrors I have ever used - should be at about £90. But not yet available for Mk2.
Roy
Thanks Roy :) .....I will have another go with the Milenco ones....these are the bigger ones not the teardrop ones....Which ones do you use :?: I will look out for those Emuk ones for the mk2 once they come out.... regards Chris :)
Chris
I use the tear drop ones.
I did email emuk and they confirmed they would have mirrors available for the mk2 at the end of 2016. But haven't seen any development yet.
Roy
Thanks Roy, I will see deffo see about those emuk ones....until then I will have another go with the Milenco. I may yet as I like my other teardrop mirrors so much, will see if I can change the mirror clamps around :arrow: :idea: :idea: Thanks mate :)
Hi Stumpy and Roy
I have also been trying to fit my old Aero2 mirrors and have come up the against same problems .
I emailed Milenco and they recommend replacing the clamps with the ones from the latest Aero3 mirrors, Part No 4589.
They are available from The Caravan Shop - Tel 01413395888 at £6.95 each which appear to be the best price.
http://www.thecaravanshop.co.uk/milenco-mgi-spares/aero-3-mirror-clamp/aero-3-mirror-clamp/prod_276.html
So choice seems to be update your mirrors with new clamps or buy a pair of shiny new ones and sell the old ones on.
Hope this helps.
Roger
Tig66 said:
Hi Stumpy and Roy
Hope this helps.
Roger
Thanks for the heads-up Roger, will give them a go :)
I've got a set of Grand Aero 3's that I use on my MK1 Tig and they are a tight fit between the glass and mirror body so will be interest on how you guys get on with the replacement attachments.
I will post some pics once I have fitted them for you to see.....mine are the 'Grand' milenco ones 'Timbo' also :) :)
Hi all
I will get some pics of my milenco mirrors attached. I do make sure when using the towing mirrors that I turn off the auto mirror park. Very easy to forget and lock car with mirrors attached.
Roy
Discussion Starter · #11 ·
Roy said:
Hi all
Roy
Ok Roy...thanks :D yes good point about the auto park mirrors, had to do that on my previous car Audi :idea:
Hi Stumpy
I'm pleased to hear that you can switch the auto mirror closing off, could be messy and expensive.
Hi Stumpy and Timbo
I am pretty certain that the mirrors do have a sensor that stops the parking drive if resistance is encountered. But since my mirrors are attached to base the resistance would be against door panel. Not ideal!!
Roy
Discussion Starter · #14 ·
Hi guys......as your idea :idea: :idea: 'Roy' you suggested, I will now a fix my mirrors to the lower housing .... 'Timbo' do you put yours top mounting or lower on the car mirrors :?: :?:
Cheers Stumpy that will be very helpful.
Discussion Starter · #17 ·
Thank's for the pics 'Roy' (great detail pics) mate.....I will try mine next time I get down to storage, as now I think having spoke to my local caravan supplier shop they sold me the latest Grand areo 3's as he said they have a very thin piece of rubber on one of the flanges for extra grip.....wait out ;) :)
1 - 17 of 17 Posts
