1 - 20 of 39 Posts
Thanks very much for the tipoff, I think I will splash out. Does the 1 month free start from purchase date or first use?
First use/When you register the App :)
Thanks mrew42 :D
Just order mine as its comparable with the tiguan mk2 and it does a DPF Re gen with my obdeleven does not.
So i will have both just in case.
Thanks for the tip off.
jools
What does the monthly sub cost?
Clearly this is cheaper than OBDEleven upfront, but over time it'll just cost the same...unless you can turn the sub on and off depending on when you need mods done?
https://caristaapp.com/pricing
£9.99
1-month subscription
£ 9.99 per month. Billed monthly.
£19.99
3-month subscription
£ 6.66 per month. Billed every 3 months.
£46.99
12-month subscription
£ 3.92 per month. Billed every 12 months.
And yes you can turn it off an on as you want (bearing in mind that once you've paid for that sub it will remain til it expires)
Thanks for the note on this - Bought one at the higher price a few days ago (which was received yesterday ... sending it back) and will buy another @ this cheaper price.
Can't wait to start playing with it over the holiday period :)
I now have both and £10 for a month its not too bad as you can just do the things that you want to do and forget it for the other 11months.
I also have OBDeleven , i had a vw golf before this for the last 3 years and i bought the obdeleven then.
Im one of these guys that looks after his money and i have been getting the free 5 a day tokens for the last few years and so far i have 3800 tokens
so far.
Yes im a bit sad.
jools
The things I changed:-
Heated drivers seat permanently on.
Rear DRLs.
The acceleration thingy (to help reduce the lag).
I'm not sure I did anything else, haven't kept my subscription for longer than the initial month.
I changed....
Throttle response setting.
Scandinavian DRL's
Needle sweep on startup.
Indicator lane change flash to 4.
Heater blower indicator level lights.
Digital dash display theme.
Electric seat back/forward when opening/closing the drivers door.
Rear DRLs.
That's a strange one! Is that for medical reasons if you don't mind me asking?
If not, I would imagine it soon will be! ;)
Essjay said:
I changed....
Scandinavian DRL's
Thanks all for the top changes .... Have made most of these yesterday.
It's a pity there's no easy way to preview the display themes without actioning the change to do so ... Unless someone knows a way?
The throttle response is this the option that has the warning against it? From over time to direct or something along those line?
Safe to do, anyone had issues with it?
Lots more options on here to the OBDeleven I have
Pete
This is how its described on the Carista website...
" Throttle response behavior
Gradual, controlled by time / Direct, controlled by threshold"
I've done this on mine (Direct) and it literally transforms the response. I know others have done it with similar results. I don't remember seeing any warning though, and there's no warning on the website.
1 - 20 of 39 Posts
