Hi there all. Just done 2000 miles in my Tig . I know this is a simple thing but the handbook says that you should check the oil level when the engine is at operating temp. I have done this and the level is near the top of the middle section of the dipstick. If I check it with a cold engine the level is half way down the section. Which is the correct way? I know it is not good to over fill. Mnay thanks from a novice!! David.
