Hello all....
Looking for either advice or someone that can point me in the right direction with my current long lasting and frustrating problem!
I have had my 2017 Tiguan since new and have never had an issue.
It is near top of the line so has all the mod-cons etc but not sure what exact model it is as all the paperwork currently sits with the mechanic who's attempting, and failing, to repair the following:
6 months ago I had a limp mode situation with the fault "Clutch sensor 2 alignment failure". This was intermittent and resolved itself intermittently over the next 4.5months with it appearing sometimes then clearing itself after reset. I decided to get it looked at as I was losing gearsets 2, 4, 6, & R during the fault and it was becoming more frequent, like once a week. I sent the vehicle to an Automatic Gearbox Specialist who identified the Mecatronic unit had a sensor fault which they repaired/replaced the sensor. When test driving they realised the Reverse gear was not available so they took it back up and assessed further. Now I am not too mechanically minded but have a general understanding so bare with me....... Apparently the synchronisation arm/lever/part is broken therefore it cannot select reverse gear. This was part cause of the Mecatronic failure or at least it is related? They have searched breakers yards, online and physically, contacted VW specialists throughout Europe and even gone to a VW recon gearbox specialist and the part simply is not available. My only option would be a new gearbox as we can't even find a 2nd hand or a recon one that will fit?
Is there anyone in this forum that knows where I can get a solution without forking out thousands on a new gearbox, bearing in mind I still need to pay a fair sum for the Sensor repair/replacement?
Thanks in advance!
Thanks in advance!
