1 - 16 of 16 Posts
Sorry if this has been asked before but, with the electric boot opening, does it give you any warning (or fail to open) if you are parked too close to an obstruction?
I don't think it does unfortunately, or at least not that I've encountered.
You can, however set the height that the boot lid will raise to, in order to avoid low garage roofs etc.
The manual also has this warning with regard to door and boot opening.
Mmmmm...that'll mess up my strict reverse parking policy somewhat. Will need to just take care! When the car finally arrives that is.
I'll have to check on mine, but I'm pretty sure if you stop reversing when the sensors have a constant beep, you'll be leaving enough space for the boot to open safely.
Pumpbhoy,
No there is no warning but if the boot sense an amount of resistances it will stop and return to the start position ie on opening will close on closing will return to open. If you have a reverse camera the red horizontal line indicates the distance you need from an object to open the boot fully (but does not take height in to consideration just the distance behind). Hope this makes sense.
Cheers. As long as the reversing camera and sensors keep you far enough away for it to fully open that's that main thing. Will still need to watch out in multi storey car parks with low roofs and pillars everywhere though!
How do you set the height of the opening? It would be great for my daughters to be able to reach the close button when they come out from school.
Saves me having to get out :D
Negativepitch,
From what I can remember on opening you press the internal tailgate button once to stop it at the height you want you then press and hold the opening button until you hear a beep and then the height of opening is programmed in.
I believe it's possible to manually move the lid to the height you want as well, and then hold the boot button and wait for the beep.
You wouldn't need to really Neagativepitch.....if the R-Line you are getting has the same function as the SEL you have a switch on the lower part of the drivers door. So you yourself can still sit in the car and operate the boot for them......
That only opens it though doesnt it?
No, it can be used to close the boot as well :p
I never even tried that :lol: just the open bit
Negativepitch said:
Hmmmm...Wally springs to mind :lol: :lol: only joking ;) ;) ;) :) Seriously though NegativePitch....when closing still pull the switch as if you were opening.....don't push down
stumpy said:
Negativepitch said:
:lol: ;)
This is something why I didn't want a Škoda, for second generation round they have for "safety reasons" boot opening only... :roll:
1 - 16 of 16 Posts
