Hello, I've taken delivery of my R Line Tig and it is better than what I remembered it to be on the test drives.
I've had a play about with things but I can't work out the following:
1 - How do I change the setting for the near side mirror so that it adjusts when in reverse?
2 - Is there a way of seeing your tyre pressure on the screen? I've found where I am able to 'set' the pressure but that's only after I've confirmed the pressures are already set correctly?
Any help is appreciated thanks
