1 - 20 of 24 Posts
View attachment 213 Hi just had Nextbase 312GW fitted at Halfords 20 min Photos 1 from drivers seat 1 from rear passengers seat hope they help. When you are driving not at all intrusive
Your camera will be covering a sensor on the front side of the mirror, needs moving to the drivers side
Many thanks will call to Halfords in the morning it's only 1 mile away thanks again
By the way what senor is it covering near the mirror??
Don't think it's in the way of any sensors where it is.
If you look though the windscreen at the mirror you'll see a square on the one side not sure what it does though
Hi Guys.
Look at the picture 'fig 168' in the on-line manual, page 243 or 281 whichever version you have access to. That shows the Lane assist camera.
That makes sense MY lane assist is showing Amber
Page 140 fig 115 number 2 it's the anti dazzle sensor
The lane assist might be orange because it hasn't established a "true lane" to assist with. Try on a motorway (without roadworks) where some lines might be clear for it to find it.
I think the sensor on the back of the mirror is the auto dimmer / anti-dazzle as miket has just said.
I did find my lane assist to be a bit iffy today but most the road were wet, also found this in the winter when a lot of leaves on the road
Pbb3 I have the same dash cam fitted due to the said sensor I fitted mine to the left of the mirror leavings approximately 5 mm between edges for adjustment to mirror if needed. After a short while front passenger will forget it's even there :D
Discussion Starter · #13 ·
Thanks guys will call in to VW before Halfords they are both on same retail park 500/600 yards apart will post back when I have correct information
From how in looks in your photos, there should be enough slack in the cable to just detach the suction mount and move it a bit to the left so it's clear of obstructing the mirror. Shouldn't be any need to take it back to Halfords. As said above, the lane assist only kicks in above 40mph.
It's not the lane assist sensor it's the anti dazzle, and what use will that be with a bright led screen only mm from it, also your not aloud by law to anything obstructing the windscreen within the sweep of the wipper blades, it will fit on the right hand side of the mirror and is where VW recommend
Will it be visible to the driver on the right hand side and therefore a possible distraction? On my last car I had mine on the left and assume dI could do the same when the Tig arrives.
I have mine on the right as per VW recommendations and don't notice it whist driving mostly hidden behind the mirror
Sorry the pictures poor but it's peeing rain and I'm not going to get tiggy wet :roll:
Thanks for that, looks ok. Any problems routing cable to drivers side?
No problem took the light/switch panel out it, only clips in but if I remember right in the end I fished a nylon fish wire all the way from the camera to the left a post, I took the a post cover off also
Ps only use soft fish wires do not use steal wire as a fish
1 - 20 of 24 Posts
