1 - 5 of 5 Posts
OEM R Line badge addition at rear.
Not usual position but thought iwould utilise addition space due to my shortned reg plate and itpaid off. Looks the business at night when illuminated by the rear reg light. &#x1f44d-1f3fb;
How do you get away with that plate?
The industry standard size front number plate is 520 mm × 111 mm (20½" × 4⅜"). Rear plates are either the same size, or 285 mm × 203 mm (approx 11"x8") or 533 mm × 152 mm (approx 21"x6"). There is no specified legal size for a number plate. For example, the rear number plate of a Rover 75 is 635 mm x 175 mm.
I've had one the same size previously on my GTI, it's completely legal, the letters/spacing etc is all fine.
As JRSTIGSEL said, the font and size is totally leagal, itsjust a shortned plate. Also ( Although you cant see it) the legal stuff you need to display has been engraved in the bottom left of the plate and can only be seen clise up, again totaly legal.
1 - 5 of 5 Posts
