1 - 6 of 6 Posts
Hi all
my left indicator light is not lighting up on the dashboard, the right works. tested by putting the hazards on.
is there a fuse for it? or its back to dealer? :?:
Are all the indicators actually working ?
It may be an indication that one of the left side bulbs has blown. Have you checked?
These days the dash bulbs are led and should outlast the car!
the actual indicators (all of them) on the outside does work, front, back and side mirror. its just not lighting up the green left on the dashboard as it should. right is fine.
what can i check?
I'd take a guess that it's central convenience controller j519 and not a cheap fix take your car back to the dealer
Maybe a new instrument cluster is required. I had a VW polo in which the electronic click that you hear when you activate an indicator stopped working. The only solution was to replace the whole instrument cluster (under warranty)
1 - 6 of 6 Posts
