1 - 8 of 8 Posts
cheers steve - that was in fact really useful.
question...not very good on this type of stuff - if i park outside my house - can i use my home's wifi??? is that the same as a hotspot?
Jon, I'm certainly no expert on CarNet, I've only used it a couple of times, but I would assume as it's only looking for a strong wifi signal, then assuming your domestic wifi signal is strong enough, and your car is close enough, then you should be ok.
I' ll give it a try when I have a spare half hour to muck about
If you park within range you can use your own wifi...I've done it myself..
Cheers,
Did that last night - I could find WiFi and connect - but car-net registration refused to work - had my code from website, but just wouldn't accept it - am at a bit of a loss.
Try getting your car as close to the wifi signal as you can to be sure you've got a strong enough signal ?.?
I've had to try things a few times to get things to work and I've put it down to signal strength.
ok - will try that in the morning, thanks
1 - 8 of 8 Posts
