1 - 11 of 11 Posts
Hi all,
Have a dsg 4 motion se nav. Done 800 miles to date and noticed a rear 'burning' smell today. Seems to be coming from both the rear wheel wells. Smell a little bit like burning runner, plastic and breaks all rolled into one. Felt the rear break discs and there not hot, so wondering if its exhaust/4 wheel drive related.
ian2087 said:
Hi all,
Is your car a diesel? if so it could be a re-gen, this can create a burning smell as you describe.
Ok, thanks. Just been doing some googling as noticed the engine fan has also been running after the engine has been turned off. Turns out it could be passive dpf regeneration, which would also explain the smell. Not lights on the dash to show its regenerating. Anyone else noticed this agree with the diagnosis?
Not really noticed a burning smell, but just a bit of newness smell coming out of the rear pipes. What I have noticed the heat which emits from the back pipes when loading the boot...
Yes it's the Re gen...agree
Now I know too. Smelt like brakes to me and I convinced myself someone had a fireplace going. The fan run on and the smell makes sense now though an information light woul have been great!
Hi I've got a 2021 tiguan 2.0tdi 4motion dsg.
I've noticed now on returning home twice the fan is in for a bit and smells hot. I've covered 498miles I guess this could be the regen. If it doesn't sort itself out I will ring vw! I will let you know what happens!
1 - 11 of 11 Posts
