1 - 16 of 16 Posts
Didn't think it was possible in an automatic but I actually "stalled" the car yesterday...
Has anyone else found that the Auto stop start cuts out before the auto hill hold/park brake comes on sometimes?
I am not overly concerned about it, but just wanted to check with others. I do say "stalled" it with a little tongue in cheek, but basically I was coming to a nice leisurely stop at a red light, foot off gas, braking slightly and was probably 'creeping' to a stop just as the lights changed - went to press the accelerator and the engine cuts out just at the time I touch the accelerator, I get my foot half way down on accelerator and still nothing. Lifted foot, pressed it again and engine starts as normal and off I go - this all happened very quickly but wife and I laughed saying that I had "stalled" the car.
I have noticed a few times though that as I come to a stop behind a car the engine cuts out before I have actually totally stopped / the park brake comes on.
Anyone experience anything similar?
Is it just my driving style and getting used to the auto or is it an area of concern?
I will keep an eye on it going forward.
Regards,
Hi Bhuna
This is normal. Auto stop is designed to cut in when the vehicle is still travelling at 1 to 2 miles per hour. Seems crazy buts that's how it's design.
Roy
Depends on how hard you press the brake pedal. I've got to be a dab hand at braking just enough to slow down or even stop without the Autostop or Autohold engaging. When I want the "hand brake", I just press a little harder.
Thanks Roy - sounds like its normal then - just a matter of timing on my part at that particular time / junction. To think I had RTFM through once already - must have missed it.
Breezer - yes - I have done that a few times, its just the first time it "stalled" on me with my foot on the accelerator.
I'll get used to it.
Don't think that's anything to do with the car being automatic. It's the way start/stop works. My current Renault Megane (manual) sometimes has a similar issue where it stops automatically at lights or when slowing to a stop just as I start to touch the clutch to start the engine to go again. I have to let the clutch up, go again and away I go.
It's just a rubbish system. Just don't like it, and have found it cuts the car out when making parking maneouvres etc, as well as one time approaching a roundabout just as I wanted to go, power cut and have to wait for it to restart.
Ironically, despite it's aim to be a climate saving device, I think it could well be the opposite and increases congestion due to the amount of cars you see taking longer than usual to set off.
I'm a long term sceptic of start/stop and dont see it as a climate change saver, more a way for manufacturers to massage emmission compliance. I cannot see how stopping and starting an engine as often is good for it as most wear occurs on start up until oil pressure builds. First thing I do on a car equipped with stop/start is turn the bloody thing off, after a while it just becomes second nature
Always switch it off! Just wish the switch was on the drivers side of the gear stick so it's not out of sight!
I'd like to see metrics on how much fuel the auto start-stop system saves in comparison (or whether it does whatsoever). Tempted to permanently shutting it down with the help of VCDS. Seems to me like VW emission shenanigans.
Stop/Start ........... Spawn of the devil. :evil:
Don't know if this has been posted before -
That spawn might be worth getting acquainted with. :lol:
I've noticed it too in the 2 days I've had the car, but now I know what's it's doing have adapted to it pretty easily. Doesn't bother me at all, and as other posters have said, being a little delicate on the braking helps.
This! If you can modulate your brake pedal pressure well, it's quite controllable. If you've got a heavy foot, you'll struggle a bit
Discussion Starter · #16 ·
Thanks all. I have got the hang of the braking etc it was just this one occasion for the "stall".
Hasn't happened again and loving the car.
Even went to a BBq yesterday and the wife said "If you want a drink tonight I can drive home as I was drinking at the last do we went to"
My response: "nah it's ok I'll drive"
Not like me at all usually.
1 - 16 of 16 Posts
