1 - 8 of 8 Posts
Can anyone confirm how many reverse lights the tiguan r line is supposed to have? Theres only 1 on mine but looks like there should be one on the other side too(see attached image)
Thank you
They only have one reverse light unless you have the IQ-Light LED Matrix. Check your rear fog light as that could be where you think the other reverse light should be.
The Facelift Elegance and full “R 320” have the full IQ lights as standard and therefore have the twin reversing lights. Other models it’s available as part of the IQ Matrix Light option.
Thank you
Hi, not sure if this can be done on the modern cars but when i had a car that only had 1 reverse light i used to just run a wire from one to the other make sure there is a bulb in other and hey presto 2 lights..
I thought about doing that on my 2010 Passat which also only has the one reverse light but on the opposite side there is the one fog light in the same place in the centre of the light cluster so couldn't change that or it would have failed the MoT.
1 - 8 of 8 Posts
