1 - 3 of 3 Posts
Have the tyres at 38psi as recommended but finding the ride a little fidgety .
Running suspension in normal setting as with the dcc in comfort it just seems to make things worse .
Might be because I've got to get used to an SUV again after running a golf r for 18 months .
Am going to drop the pressures a couple of psi as I normally do if the tyre pressure monitoring will let me .
I agree with you that I find comfort setting in dcc not that comfortable! Mind you I find normal for everyday use and motorways fine and sport ideal on twisty roads. Haven't found either fidgety. However what model and wheel size are you on. I am an SEL 190 TDI with standard 19" wheels.
The same ,standard 19" wheels with 50 profile tyres ,without going out to the garage I can't remember the full size.
Wanted a bit more comfort than I had in the golf which was 35 profile and that's why i didn't go for the optional 20s .but have to say I like the colour of the standard Victoria wheels as it looks a slightly darker colour to the normal silver alloys.
1 - 3 of 3 Posts
