What made you buy a VW...this did
Second generation qashqai 14 reg from new...its a long list :mrgreen:
Nissan quashqai, a great car.....ours.....
A 14 reg plate from new.
Dead faulty car battery, 'system fault' hill start assist would not release after having a new module fitted.
Loud rattle now in dash, from air ducting, dash out again. mechanic said its the worst design he as ever come across, the air ducting is just free floating.
Dash out (for the third time) as something or another has come lose in it.
Left hand side exhaust mount has completely snapped off, as I was collected the car, as I pulled off from the dealer, the rear seatbelt warning light would not go off, turn a round and straight back into dealer
Something hitting the passenger window inside the door.
Hill start assist failed for the third time, and needed a new module fitted.
Longest the car was in was for 5 weeks a few months ago.
From front trim falling completely off or the plastic chrome around the windows discolouring and replaced to having the small info screen (the one that sits in the middle if the speedo/revs) replaced twice.
New wing mirror twice) first replacement was scratched..well..small chip which they did apologise for replaced it for a used one. Eventually replaced it for a new one. (I think they thought I would not have noticed it).
Faulty front sensor recall, the sensors pick up heavy rain and mistake it to set off the city brake alarm. no full fix by nissan, as they are still working on it.
Interior trim panel in boot warp causing it to pop out of its mounting clips by two inches.
Loud chinking sound in drivers door which turned out to be a lose part on the anti theft device in the door.
Auto head lights staying on all the time, had to turn them off manually until fixed, part of the 5 week stay with nissan.
Left hand gas strut on the boot failed.
Mudflaps fitted, missed two mounting screws.
Drivers window dropping slightly after a few miles on rough-ish roads.
Rattle from air vents, common problem, well documented, no fix on the first production cars.
Ive had a vibration noise from day one, that they cant seem to locate. not mechanical, but loud when pulling off from cold on an incline.
Hill start assist packed in, part of the 5 week stay.
A bolt holding part of the aircon ducting in the engine bay sheer off.
other small bits and bobs, door sill guards both scratched when installing.
Rear seat arm rest stopped fully pulling down.
Steering making a groaning noise, it was a plastic collet that is used needing lubricating. (well documented)
Air con has just packed in all together. (they tried re-gassing it)
Other small stuff that I cannot quite remember.
Something loose in the dash but couldnt be arssed as I was trading it in anyway.
Would definitely recommend the car.
