Closing boot with key MY2019
Essjay
Re: Closing boot with key MY2019
Post by Essjay » Mon Jun 10, 2019 5:53 pm
I know mine’s a 2016 model, but on one or two rare occasions I’ve pressed the right hand button and walked away and the boot hasn’t closed itself, and I’ve been at my front door before I’ve realised, I’ve just used the remote button to close it. I must have been around 20 feet away, but it’s still closed ok.
Tiguan 2.0 TSi 180 SEL DSG 4MOTION (Sept ‘16, but MY17).
Caribbean Blue, Vienna "Storm Grey" leather, Keyless and electric tailgate, Tyre Pressure Monitor (TPMS), Area View, Park Assist, HUD, Winter Pack, Michelin Cross Climate SUV tyres
Bruce287
Post by Bruce287 » Mon Jun 10, 2019 6:03 pm
JK-VWTiguanR wrote:
Mon Jun 10, 2019 5:35 pm
scrounger wrote:
Mon Jun 10, 2019 5:30 pm
if you are taking stuff out of the boot and your hands are full, before you pick everything up, press the button to the right of the boot close and when you go out of range by about 4 feet, the boot will close itself.
Good point. :)
As mentioned before I'm aware that I can use the buttons to close the boot.
In summary then, I've found that late 2018 and onwards models you cannot close the boot with the key unless you are close to the boot.
Cheers for confirming
Previous car - 2017 R Line, 240 BiTDI, white, leathers
Own - 2019, R LIne Tech 230 TSI, white, TMS, Dynaudio and leathers
JK-VWTiguanR
Post by JK-VWTiguanR » Mon Jun 10, 2019 6:43 pm
Good point. :)
How far away did you want to use it?
PanMan
Post by PanMan » Mon Jun 10, 2019 9:23 pm
It is probably a 'safety' thing. With the Allspace, you can't shut the boot by key fob from anywhere, the assumption being you should be at the boot to make sure your third row passengers are aware that the boot is about to close.
For the standard model, someone has decided that you should be close enough to see that it is safe to close the boot, whilst not being so close that the boot door will hit you on the way down , eg. leaning inside the car and squishing the fob in your pocket that activates the closure.
MY18 Tiguan Allspace SEL TDI 240PS Blue Silk; Vienna leather in Titan Black; Area View; Head up display; Park Assist and rear view; Discover Pro; Heated windscreen + Qi charging; Heated steering wheel; Tyre pressure monitor
brian1983
Post by brian1983 » Tue Jun 11, 2019 6:50 pm
I tried to close my boot from inside my house last night. No joy, I was about 10 feet away, opened no problem, nothing happens when I tried to close it, had to go out and hit the button, 2019 standard Tiguan
2019 R-Line 150 Bhp White
JK-VWTiguanR
Post by JK-VWTiguanR » Tue Jun 11, 2019 7:14 pm
Did you press and hold the boot close button?
brian1983
Post by brian1983 » Tue Jun 11, 2019 7:16 pm
Yes. I tried that and the lock button, nothing worked
JK-VWTiguanR
Post by JK-VWTiguanR » Tue Jun 11, 2019 7:26 pm
Strange how some peoples works and others do not.
brian1983
Post by brian1983 » Tue Jun 11, 2019 7:28 pm
Must be year difference or something, haven’t checked the manual to see what it says there though.
Russboy
Post by Russboy » Wed Jun 12, 2019 7:50 am
Tried mine last night and can open and close via the remote.
2019 Tiguan R-Line Tech 2.0 petrol 230ps with running boards, Blackvue DR750S-2CH, Maxton design front splitter and rear spoiler extension, TPMS, Heads up display, Swivelling Tow Bar, fully lined boot for protection from the hounds!
Return to “Faults & Technical”
VW Tiguan MK2 Forums
