VCDS Info Swap
VCDS Diagnostics Forum
germanguy
VCDS Info Swap
Post by germanguy » Fri Jun 02, 2017 7:37 am
Hello there,
I'm a german Tiguan Driver equipped with vcds. I registered on your Forum cause I want to find someone who can give me some vcds STG09 exports of a english tiguan. For example, our fog light (on led tail lights) is on the left side, yours is on the right. I want to have a look to an englisch vcds export to check about its possible to enable both fog lights (its legal here in gemany to have two). I allready checked to enable the right one but all what happened that the right break lights went on. So I'm on the way of discovering with try and error.
Here it Looks like from default:
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 27,32 - allgemeine LED
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Bremslicht
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Nebelschlusslicht wenn kein Anhaenger gesteckt
As you see, the left fog light is configured and the right one is a (dummy) entry for the break light
I tried to adjust it for the right side with:
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion C 27,nicht aktiv
But this lights the right break light instead of the fog light. So, the data from your STG09 would be helpfull for me.
germanguy
Re: VCDS Info Swap
Post by germanguy » Tue Jun 06, 2017 3:56 pm
Nobody interested to help? :cry:
Miket
Re: VCDS Info Swap
Post by Miket » Tue Jun 06, 2017 4:24 pm
When I get my cable back off the nephew I'll have a look for you
2.0TDI BMT 190 4Motion R-Line tech 5dr DSG metallic silver
Breezer
Re: VCDS Info Swap
Post by Breezer » Tue Jun 06, 2017 4:25 pm
I think there's some members on here that have started, and contributed to, VCDS threads - a quick search for VCDS has a fair amount on the subject.
I read your post, and as I know no German (or much about VCDS), the content means very little.
SEL 2.0 TSI 4WD DSG
Ruby Red+Area View with Park Assist +DCC +Electric Tailgate & Keyless Entry +Heated Windscreen +Wireless Charging +Tyre Monitor +Leather Seats
Ord: 20/02/17 | Built: 03/04/17 | Landed: 21/04/17 | Rec: 02/05/17
welshkaiboy
Re: VCDS Info Swap
Post by welshkaiboy » Thu Jun 08, 2017 12:12 pm
Germanguy
Sent you a link to my 09 module via PM
germanguy
Re: VCDS Info Swap
Post by germanguy » Thu Jun 15, 2017 6:13 am
Thanks in advance to @Miket I'll wait for it
I allready answered your PM @welshkaiboy unfortunatelly there is no way to pass the Problem on your old versioned bcm (stg09)
cabby09
Re: VCDS Info Swap
Post by cabby09 » Sat Jul 01, 2017 4:52 pm
Heres my standard fog coding from a RHD. I have the fog light on the right hand side with the left one not " working "
Hope it helps.
Cheers Brent
2017 1.4TSI Manual R-Line Pure White
(South Africa)
