Adblue - reset the warning manually
Mixtu
Post by Mixtu » Fri Jul 21, 2017 8:23 am
Has anyone had to do this? I put in 4 litres and I am still getting a warning saying I need to re-fill in 200 miles! I read some Touareg and Passat owners having to reset manually as the car doesn't do it if you add less than 5-6 litres.
If anyone has experienced this it would be good to know?
cheers
M
Ordered 29th Sept 2016 – Delivered 20th March.
Tiguan R-Line 2.0 TDI 4Motion 150PS 7-Speed DSG - Debadged - White - Park Assist - Reversing camera
c_w
Re: Adblue - reset the warning manually
Post by c_w » Fri Jul 21, 2017 10:40 am
Yes I think you're better filling it fully back up otherwise it doesn't reset properly.
rockman2
Post by rockman2 » Fri Jul 21, 2017 1:11 pm
cheers
M
After you put it in did you turn on the ignition and leave it for 30 seconds or so before starting the car ?
MK2 Tiguan 2.0 150TDi S Deep Black Pearl with nothing apart from a couple of chrome exhaust tips and replacement headlight bulbs.
Mixtu
Post by Mixtu » Sat Jul 22, 2017 10:14 am
yes, warning went away but its back on again.
JK-VWTiguanR
Post by JK-VWTiguanR » Mon Apr 15, 2019 1:17 pm
cheers
M
Just had to put addblue into our car for the first time and filled all the way up, left ignition on for 30 seconds and it still tells me to add the adblue, anyone found out how to remove this?
2018 18-Plate 240hp Tiguan R-Line in White with Loads of Extras.
On Order: 2019 19-Plate 230hp Tiguan R-Line Tech in White with Loads of Extras
F2paul
Post by F2paul » Mon Apr 15, 2019 1:21 pm
I`ve topped up a couple of times ,full 10l and hadn`t bothered with the 30 seconds ignition on. It immediately registered the adblue full range on the display.
2.0 Tdi , DSG , SEL 4 motion Indium Grey. Collected 31.1.18
JK-VWTiguanR
Post by JK-VWTiguanR » Mon Apr 15, 2019 1:22 pm
Strange how some cars do register and others are not.
CNC
Post by CNC » Mon Apr 15, 2019 5:14 pm
You must be careful to put in an amount that it states on the dash, it will give a minimum and maximum amount.
Put too much in and it can confuse the system, as can putting too little in.
If you put too much in you can cover the level sensor which then can't see the level at all so gives a false warning.
Return to “Main Volkswagen Tiguan chat”
VW Tiguan MK2 Forums
