Tyre Pressure
Still Game
Tyre Pressure
Post by Still Game » Tue Jul 16, 2019 12:36 am
I was filling up my tank today and decided to check the tyre pressure for the 1st time, I was a little surprised to see them set so high 43 and 42, so I was wondering what pressure you guys run, just out of curiosity 🤔
milligan
Re: Tyre Pressure
Post by milligan » Tue Jul 16, 2019 2:39 am
When I picked up my Tiguan the pressures were the same as you found. Luckily, with the TPMS system fitted I have a visual readout of the pressures and the first thing I did was reset the tyre pressures to ‘normal’ which is 38 psi. The TPMS system has three settings, ‘normal - 38, ‘comfort - 34 (I think) and a high pressure setting which I forget the name of which is 42 psi(I think).
Tiguan SEL 2.0 TDI 4M 190PS DSG, Tungsten Silver, TPMS
Ordered 11/6/2018
Handover 11/01/19 :D :D Only 214 days!!
Old AID fitted :roll:
Pano roof lights reinstated 16/10/19 :D :D :
chrisb
Re: Tyre Pressure
Post by chrisb » Tue Jul 16, 2019 7:21 am
When I collected ours they were set on 42 but after a couple of weeks I reduced them to 38 so now a bit softer ride ! :D
2019 SE-NAV 2WD TDI 150PS MANUAL IN TUNGSTEN SILVER, TITAN BLACK
VIENNA LEATHER.
niggly58
Re: Tyre Pressure
Post by niggly58 » Tue Jul 16, 2019 7:47 am
Tyre pressures are stated on a label in the drivers door opening and will vary according to the tyre size and engine type.
On mine, a diesel fitted with 19 inch wheels, the standard pressure is 38psi- the Comfort pressure is 33 and the Max Load pressure is, I believe 42psi.
I normally run mine at 38psi.
2016 VW Tiguan Mk2 2.0L SEL 150 4Motion Manual Diesel. Indium Grey.
Vienna Black leather, electrically adjustable. 4 heated seats. Stainless exhaust trims, K&N 33-3005 air filter. RLine pedal covers. Michelin Pilot Sport 4 SUV tyres.
Still Game
Re: Tyre Pressure
Post by Still Game » Tue Jul 16, 2019 8:13 am
Yeah I know the label is there that's why I was surprised at the higher pressure in the tyres
Like you guys I put them down to the 38 as per the instructions on the label 👍🏻
MM5
Re: Tyre Pressure
Post by MM5 » Thu Aug 01, 2019 2:15 pm
I just checked mine for the first time since delivery 30th may and they are all on 52??? Wtf
2019 Tiguan SEL 190 TDi in Black
chrisb
Re: Tyre Pressure
Post by chrisb » Thu Aug 01, 2019 3:39 pm
Must have set at 3.8 bar instead of 38 psi. :(
VIENNA LEATHER.
xtrailman
Re: Tyre Pressure
Post by xtrailman » Fri Aug 02, 2019 6:41 am
Don't forget to check pressures when cold so not after a run, and not after being parked up stationary all day in the sun.
Best time I find is early morning before sunrise.
I also have TPMS and often see 2psi difference due to one side being in the sun, after its been parked up all day.
And I run at 38psi.
2019 SEL 190ps diesel.
ZaheerUK
Re: Tyre Pressure
Post by ZaheerUK » Sat Aug 03, 2019 9:46 am
Ok - so
Have seen guys on here with SEL 19” tyres running at 38psi. Anyone here with R-Line 20” tyres? What do you recommend running the tyres at?
VW Tiguan R Line Tech DSG 2.0 TDi DSG Indium Grey inc HUD, Rear Heated Seats, TPMS, Emergency Assist
Tubemonster
Re: Tyre Pressure
Post by Tubemonster » Sat Aug 03, 2019 4:51 pm
Ok - so
38 psi as the plate by the drivers door states.
Tiguan SWB R-Line Tech 2.0 TDI 4Motion 190PS 7 Speed DSG - Tow bar
Ordered 11/08/18 ///Build date 21/01/19///In Transit 19/01/19 (early)///Arrived in UK 24/01/19
Collected 16/2/19 🎉
Return to “Main Volkswagen Tiguan chat”
VW Tiguan MK2 Forums
