Tyre Pressure
ZaheerUK
Re: Tyre Pressure
Post by ZaheerUK » Sun Aug 04, 2019 5:31 pm
Tubemonster wrote:
Sat Aug 03, 2019 4:51 pm
ZaheerUK wrote:
Sat Aug 03, 2019 9:46 am
Ok - so
Have seen guys on here with SEL 19” tyres running at 38psi. Anyone here with R-Line 20” tyres? What do you recommend running the tyres at?
38 psi as the plate by the drivers door states.
That’s the same as mine mate - but if you look closely those readings are for R18 tyres. I want to know what the optimum settings are for R20 tyres.
VW Tiguan R Line Tech DSG 2.0 TDi DSG White
13/03 - S1 - Processing
26/03 - S2 - With Factory
30/05 - S3 - BWC
27/06 - S5a - Transit
03/07 - S5b - Shipped
05/07 - S5c - Near UK
09/07 - S6 - Arrived in UK
15/07 - Collected!!
chrisb
Re: Tyre Pressure
Post by chrisb » Sun Aug 04, 2019 5:53 pm
Ok - so
Isn’t the r18 just the spare?
2019 SE-NAV 2WD TDI 150PS MANUAL IN TUNGSTEN SILVER, TITAN BLACK
VIENNA LEATHER.
Tubemonster
Re: Tyre Pressure
Post by Tubemonster » Sun Aug 04, 2019 6:42 pm
Ok - so
If you look as closely as you want me to, you will see that the R18 refers to the spare 😉
Tiguan SWB R-Line Tech 2.0 TDI 4Motion 190PS 7 Speed DSG - Tow bar
Ordered 11/08/18 ///Build date 21/01/19///In Transit 19/01/19 (early)///Arrived in UK 24/01/19
Collected 16/2/19 🎉
ZaheerUK
Re: Tyre Pressure
Post by ZaheerUK » Mon Aug 05, 2019 9:06 am
Aaah! My bad!
30/05 - S3 - BWC
15/07 - Collected!!
chillyman50
Re: Tyre Pressure
Post by chillyman50 » Mon Aug 05, 2019 9:37 am
milligan wrote:
Tue Jul 16, 2019 2:39 am
When I picked up my Tiguan the pressures were the same as you found. Luckily, with the TPMS system fitted I have a visual readout of the pressures and the first thing I did was reset the tyre pressures to ‘normal’ which is 38 psi. The TPMS system has three settings, ‘normal - 38, ‘comfort - 34 (I think) and a high pressure setting which I forget the name of which is 42 psi(I think).
FULLY LOADED :D
TIGUAN SEL 190PS TDI-4 MOTION, white metallic silver, DCC, Dynaudio, Voice,Leather/electric seats, Camera, Headlight wsh, sidescan, swivel towbar, added immobiliser,others
chillyman50
Re: Tyre Pressure
Post by chillyman50 » Mon Aug 05, 2019 9:39 am
I set mine at 2.7 on the front and 2.8 on the back. I found fuel economy is better and the tyres don't sit so flat on the road. it so helps when loading up the car for short trips
