Why no details? It would help others. Is it top secret stuff.
Dynamic wing mirror indicators
Re: Dynamic wing mirror indicators
Tiguan R Line Tech 2.0L BiTDI
Orxy White, Leather with Heated Rear Seats, Pro Nav, Dynaudio & TPMS.
28/8/19 Ordered, 8/11/19 Collected, Yes!
Think I'll be leaving as standard!
Sent from my SM-N950F using Tapatalk
Just having installed these I noticed it’s the right side wing he’s focusing on in the video. From what I read and even experienced the right female connector is tight (that’s what she said), so look and make sure it’s in flush. Don’t go by what feels like a click. I had a similar issue, the light worked but when everything was reassembled it had a short. I had to disassemble and finally noticed the male connector wasn’t all the way in and flush.
I guess you can ask him for details via his YouTube channel
Thanks for the very useful comment.
Given the chance, do you have a 2017-built model?
This was my initial query before messing with synchronization issues
Reihenmotor5 wrote: ↑Tue Dec 17, 2019 4:20 pmJust having installed these I noticed it’s the right side wing he’s focusing on in the video. From what I read and even experienced the right female connector is tight (that’s what she said), so look and make sure it’s in flush. Don’t go by what feels like a click. I had a similar issue, the light worked but when everything was reassembled it had a short. I had to disassemble and finally noticed the male connector wasn’t all the way in and flush.
2019 SEL-P
Did a quick Google, and found this...
"The only thing that makes me feel unhappy was the description on how to install it was not clear, they gave a diagram with 3 wires,. But the real product have 4 wires,.you should connect the red to acc and black to negative then the green wire to left side signal and the yellow wire to the right to make it functionally synchronized with the signal lights."
SEL 2.0 TSI 4WD DSG
Ruby Red+Area View with Park Assist +DCC +Electric Tailgate & Keyless Entry +Heated Windscreen +Wireless Charging +Tyre Monitor +Leather Seats
Ord: 20/02/17 | Built: 03/04/17 | Landed: 21/04/17 | Rec: 02/05/17
That’s odd, since the OEM pieces have a male connector that connects to a female connector in the housing. The Jogons have the same connector, just plug n play. Why would you have to connect up wires unless they’re requiring you to splice in?
Hi all,
Has anyone fitted them to a 2018 Nav and if so where there any problems due to this model not having LED lighting.
Regards
Regards
Tiguan has landed in the UK and pick-up 1/3/2018...
150hp TSI, ACT Manual, SE Nav in Urano Grey with Panoramic Roof, Leather,
heated seats, tyre pressure monitor, Park Assist & Rear Camera.
- dsaunders70
Fitted my dynamic indicators this morning. only took about 20 minutes per side.
No issues with the sequencing on either side. Just make sure you push the connector in properly.
Really pleased with them.
Pruchased from Aliexpress, they came really quickly
https://www.aliexpress.com/item/3301359 ... 4c4dkz6Ruq
Videos below of the sequencing.
R-line 150 TDI|White|Keyless entry & auto tailgate|Dynaudio Excite|Side Scan |Swiveling towbar|4th year warranty |4 Year Service Plan (First 2 years Free)
Picked up on Saturday 18th March 2017 and loving it..!
