In Eco mode or Not .
Dave1510
Re: In Eco mode or Not .
Post by Dave1510 » Wed Sep 16, 2020 8:25 pm
How can you tell if a DPF burn is happening ?
I thought the Ad Blue was to prevent the need...?
Also
Given that 2WD Cars won’t coast in D, I’ve also discovered that even if there are trees round the Lane assist icon, and the mode button is lit, and the info screen says eco, if the gear indicator says D, the car won’t coast, so unless it says E it’s not in Economy (apparantly).
Have VW got a take on this ?
20 plate Tiguan RLine tech Allspace (White) 150 Diesel DSG; remote tailgate, all round cameras, keyless entry& start and sidescan.
Replaced (Aug 2020)16 plate SEL in black with all round cameras and heads up display
windshear
Post by windshear » Thu Sep 17, 2020 8:49 am
Also
DPF and Adblue has different aims.
You understand the DPF burn starts when the idle RPM is stuck around 1000(normally 750), engine is slightly vibrating and start stop does not engage. Also, after couple of minutes of DPF burn the coolant fan runs at higher rpm and even if you shut the engine, it continues to run the fan for couple of minutes as during the DPF burn the system elements get really hot.
2020 Tiguan GT Executive Edition 2.0 TDI 190 4Motion R-Line - Indium Grey
Dave1510
Post by Dave1510 » Thu Sep 17, 2020 9:41 am
Ah right, I recall these things on my old Tig. I didn’t realise that’s what was happening. Now I’ll be aware of it.
On my old Insignia, I used to get a message “do not switch off engine whilst this message shows” (or words to that effect)
sliveredge
Post by sliveredge » Thu Sep 17, 2020 4:05 pm
My 2wd petrol coasts while it’s in normal D mode
Dave1510
Post by Dave1510 » Thu Sep 17, 2020 7:37 pm
Is Petrol different to Diesel in this. My 2WD diesel doesn’t appear to coast in D (even if the other indicators say it’s in Eco...
Matt320uk
Post by Matt320uk » Thu Sep 17, 2020 8:41 pm
No, my 2WD Diesel Allspace coasts now and again in D. Just not as often as when it’s in E mode.
Allspace R-Line Tech
2.0D DSG. Swivel towbar. Sidescan.
Ordered mid January 2019
Confirmed build week 15 (mid April)
Left factory 11th May
Arrived in UK 1st June
Arrived at dealer 5th June
Delivery due 10th June
Dave1510
Post by Dave1510 » Thu Sep 17, 2020 8:48 pm
I’ll have to keep an eye on things to see if mine (sometimes) coasts in D.
Tricky
Post by Tricky » Thu Sep 17, 2020 10:01 pm
Different car, but related to coasting: A while after getting the misses T-Cross I noticed occasionally an eco symbol on the dash, together with gear display going to D and the revs dropping to idle. All signs it's going into coasting. Trouble was it wasn't consistent like you'd lift off 5 times, and maybe get coasting once. However more recently it's doing it maybe 4 out of 5 times, and as mentioned previously can be invoked by a tap on the accelerator.
I do drive a lot of the time with an eye to economy, not slowly, but once up to speed a light throttle and lifting off where I can. I believe it's detected this, and going into eco more frequently in response. So in this sense it is learning how you drive I think.
