Hteepee
I reckon the key must communicate the key battery voltage back to the car...has to be.
T
Battery Memory savers
Re: Battery Memory savers
I wondered the same, but don't see how. I don't see how age of battery is how it works (2nd battery fob lives in house unused, but worked when first fob failed). Total mystery, but so long as swapping battery clears message on infotainment screen and continues to operate central locking then that will have to do I guess.
R-Line 190 4Motion DSG White. Swivel Towbar Running Boards.
Mine came up with the change key fob battery message last week each time I started the car. Just to check on the process before I had access to a replacement, I removed the old battery and then put it straight back in. The message then cleared and stayed away, didn't come back even after several days before I was able to fit a new battery. When I checked the old battery it was coming up as 95% full on the tester. So I guess it can't be based on actual condition - maybe length of time since last changed or else number of times used?hteepee wrote: ↑Sat Jan 09, 2021 8:52 pmI wondered the same, but don't see how. I don't see how age of battery is how it works (2nd battery fob lives in house unused, but worked when first fob failed). Total mystery, but so long as swapping battery clears message on infotainment screen and continues to operate central locking then that will have to do I guess.
2019 2.0 TDI (190 ps) SEL SCR 4MOTION DSG Atlantic Blue metallic swivelling towbar
- Tubemonster
Carista showed up a fault code on mine No/.204546 which said "Remote Key 2- current too low" I replaced the battery and it hasn't come back.
Could be dirty/corroded contacts and taking it out and replacing it was enough to clean it. Bit like when the old TV remote starts playing up so you remove the back and rotate the AAAs and hey presto it works againBlackstar wrote: ↑Tue Feb 16, 2021 11:38 pmMine came up with the change key fob battery message last week each time I started the car. Just to check on the process before I had access to a replacement, I removed the old battery and then put it straight back in. The message then cleared and stayed away, didn't come back even after several days before I was able to fit a new battery. When I checked the old battery it was coming up as 95% full on the tester. So I guess it can't be based on actual condition - maybe length of time since last changed or else number of times used?hteepee wrote: ↑Sat Jan 09, 2021 8:52 pmI wondered the same, but don't see how. I don't see how age of battery is how it works (2nd battery fob lives in house unused, but worked when first fob failed). Total mystery, but so long as swapping battery clears message on infotainment screen and continues to operate central locking then that will have to do I guess.
That is very possible. I did also wonder about the cold weather as where the key is kept is in part of the house that isn't always heated. Anyway, for the sake of the cost of a battery I've left the new one in and also put a spare new battery in the glovebox in case the other fob goes.mrew42 wrote: ↑Wed Feb 17, 2021 10:14 amCould be dirty/corroded contacts and taking it out and replacing it was enough to clean it. Bit like when the old TV remote starts playing up so you remove the back and rotate the AAAs and hey presto it works againBlackstar wrote: ↑Tue Feb 16, 2021 11:38 pmMine came up with the change key fob battery message last week each time I started the car. Just to check on the process before I had access to a replacement, I removed the old battery and then put it straight back in. The message then cleared and stayed away, didn't come back even after several days before I was able to fit a new battery. When I checked the old battery it was coming up as 95% full on the tester. So I guess it can't be based on actual condition - maybe length of time since last changed or else number of times used?hteepee wrote: ↑Sat Jan 09, 2021 8:52 pmI wondered the same, but don't see how. I don't see how age of battery is how it works (2nd battery fob lives in house unused, but worked when first fob failed). Total mystery, but so long as swapping battery clears message on infotainment screen and continues to operate central locking then that will have to do I guess.![]()
Interesting to see that the OBD does actually sense the battery current.
It came up on daughter's SEAT Ateca (so I'm assuming same system) 3 mths after the dealer changed the key battery. Actually I say "came up" - she hadn't seen the warning at all because with keyless start you don't see it (or maybe it's there extremely briefly). It's only when I turned the ignition on (by trying to start the car without clutch depressed) did the warning become obvious. Seems a poorly thought out way of warning.Blackstar wrote: ↑Tue Feb 16, 2021 11:38 pmMine came up with the change key fob battery message last week each time I started the car. Just to check on the process before I had access to a replacement, I removed the old battery and then put it straight back in. The message then cleared and stayed away, didn't come back even after several days before I was able to fit a new battery. When I checked the old battery it was coming up as 95% full on the tester. So I guess it can't be based on actual condition - maybe length of time since last changed or else number of times used?hteepee wrote: ↑Sat Jan 09, 2021 8:52 pmI wondered the same, but don't see how. I don't see how age of battery is how it works (2nd battery fob lives in house unused, but worked when first fob failed). Total mystery, but so long as swapping battery clears message on infotainment screen and continues to operate central locking then that will have to do I guess.
So it looks like it is checking the battery condition. Not unheard of - other daughter had a Mitsubishi Colt and that flashed the indicators like mad on unlocking when the key battery was low - didn't know what the heck was going on first time it did it.
near Chester, UK
Sept 2015 Match 150PS TDI 4Motion DSG (hers) - thinking of a mk2, maybe an Allspace, for him.
Added Sept 2018 SEAT Ateca SE-L 1.0TSi 2WD manual to the family 'fleet'.
