Retrofit wireless charger
Hi
Has anyone fitted a retrofit wireless charger that they can recommend?
Ideally one that can be done via a DIY?
R
R
Tiguan Allspace RLine Tech
2.0tdi 190 4 motion
2.0tdi 190 4 motion
Re: Retrofit wireless charger
Hi,
Just a heads up for future, If you type Wireless Charger in the search box your find a few links to other threads asking the same questions with some links to other products that people have looked at.
Here's what I got when I tried this search on this site,
search.php?keywords=wireless+charger
Hope this assists you but if there is nothing there that helps then come back and ask away on here, I am sure someone will be able to assist.
https://www.carsystems.eu/wireless-char ... d3570.html, if you use this ,link it will direct you to a company in Poland who do a kit, pad and wiring loom
Thanks for that have you got this? Do they provide instructions on how to fit this, Also was it a diy job?Sinclair0755 wrote: ↑Mon Feb 22, 2021 10:07 amhttps://www.carsystems.eu/wireless-char ... d3570.html, if you use this ,link it will direct you to a company in Poland who do a kit, pad and wiring loom
Thanks again
2.0tdi 190 4 motion
2.0tdi 190 4 motion
I'm intending to get one, looking at the wiring loom in the advert, it looks like there is a positive and negative feed and some canbus connections required I believe to show the charging display when charging, as for the aerial connection you can get a compatible aerial from ebay for under £10 I had the same type of aerial on my 15 plate Tiguan r, I am going to do some more research on the fitting.
That's a lot of money, think i will stock with plugging in the USB cable.
I just bought one of these;
https://www.ebay.co.uk/itm/2-In-1-Car-Q ... 2749.l2649
Plugs into a USB adapter in the 12v socket. Charges my iPhone 12 Mini with no problems. It's not an OEM looking solution, but for under £15 its fine.
67 Plate, Pure White Tiguan 2.0TDI 4 Motion manual, electric tailgate, Miramar Grey 20" alloys and sports suspension.
Hey that’s a great find, got any pics of how it looks the cable looks really long how have u hidden it?ExAudiSi wrote: ↑Mon Feb 22, 2021 7:47 pmI just bought one of these;
2.0tdi 190 4 motion
2.0tdi 190 4 motion
- Tubemonster
Where it says "can be pruned I thought it meant the lead not the actual trayRusty04 wrote: ↑Tue Feb 23, 2021 12:03 pmHey that’s a great find, got any pics of how it looks the cable looks really long how have u hidden it?ExAudiSi wrote: ↑Mon Feb 22, 2021 7:47 pmI just bought one of these;
I've left the cable rolled up and then used double sided tape to fix the part with the electronics into the roof the pocket. It also has a red power light which is useful as it shines down onto the mat and illuminates the pocket.
I am thinking about cutting a hole into the rubber mat so it sits a bit more flush and adding a USB adapter behind the console so that the wiring can be all hidden out of sight. I have bought another mat so that if it doesn't look right I can go back to standard.
I did think about mounting it under the pocket, but it doesn't have the range to reach through the pocket to charge the phone.
