Wet Footwells Driver Side Front and Rear
peterg
Re: Wet Footwells Driver Side Front and Rear
Post by peterg » Fri Jun 14, 2019 12:00 pm
Add me to the list. Because my drive is qiuite steep I park sideways on to the house and always reverse in, therefore the nearside of the car is lower than the offside.
Last night, after having not used the car for three days I saw that the front passenger footwell carpet was saturated ( see photo ) and there was water droplets on the passenger visor, no other area appears to be effected.
I had the sunroof modification carried out a few weeks ago, prior to that no problems.
Like Tiggy I have booked my car in to Listers in Worcester so hopefully will get a similar positive experience.
2.0 150 DSG 2WD Caribbean blue, 20" Miramar wheels,heated seats & steering wheel + paddle shift, wireless smartphone charger, keyless entry/stopstart, heated front windscreen, electric tailgate, heads up display, sports suspension,
kenville
Post by kenville » Fri Jun 14, 2019 6:57 pm
It’s quite concerning to read about this problem. I had this really bad on my Mark IV Golf and you would’ve thought VW would know by now what causes this. Costs a fortune to sort out if not under warranty.
chillyman50
Post by chillyman50 » Mon Jun 17, 2019 12:38 pm
take to a main dealer. its their problem to fix. they will want to keep the car for three days. this is free of charge.
TIGUAN SEL 190PS TDI-4 MOTION, white metallic silver, DCC, Dynaudio, Voice,Leather/electric seats, Camera, Headlight wsh, sidescan, swivel towbar, added immobiliser,others
peterg
Post by peterg » Fri Jul 05, 2019 1:24 pm
Have now got my car back with the dealers having fitted new carpets, the problem was blocked drainage channels from the sunroof so hopefully all now sorted , didn’t get an opportunity to have a courtesy car as apparently they needed 10 days notice, pity as I would have liked the chance to try out a T Roc with a view to replacing my wife’s Hyundai., otherwise no complaints about my dealer experience.
Post by JK-VWTiguanR » Fri Jul 05, 2019 3:03 pm
As this is a known issue for some time I wonder if they have done any remedial work on the new built Tiguan to stop this issue.
Chris
Post by Chris » Sat Jul 06, 2019 2:10 am
The drains from the roof should be a service check for blockage and it is for some manufacturers I am told. If it isn't for VW I would be making a point of it and want proof it was looked during each service. It is a fairly simple exercise for them to do using compressed air to clear any debris in there. I wouldn't have a sunroof for a bet and this is one of the reasons.
White 162kw/217.246hp, DSG
collidog
Post by collidog » Sun Jul 07, 2019 7:58 am
Does anybody know where the drains exit?
The mk4 Golf was well known for the rubber exit points for the sunrooof drains (near the front door hinges) to become stuck closed, allowing the water to back fill and then spill out into the car. A squeeze to release then every so often was required. Speaking from experience of flooded car.
R-Line|BiTDI 4Motion 240 PS DSG|Atlantic blue|Vienna leather|Electric tailgate|Winter pack|Park assist + rear view camera|Side scan|Tow bar|Tyre pressure monitoring system|Dynaudio|Ordered 15th May|Week 26 build|At dealer 11th July
chillyman50
Post by chillyman50 » Sun Jul 14, 2019 3:42 pm
dealer, don't bother doing anything else. their problem to fix, tell to fix it.
Post by Essjay » Sun Jul 14, 2019 4:29 pm
If you do decide to do something yourself these may help.........
Tiguan 2.0 TSi 180 SEL DSG 4MOTION (Sept ‘16, but MY17).
Caribbean Blue, Vienna "Storm Grey" leather with memory, Keyless and electric tailgate, Tyre Pressure Monitor (TPMS), Area View, Park Assist, Protection pack and HUD.
Post by JK-VWTiguanR » Sun Jul 14, 2019 4:41 pm
Is it the hose that blocks or the drain hole?
If it is the hose why do they just not fir a larger diameter hose.
Return to “Faults & Technical”
