Mpg
New to the Tiguan Forums? Introduce yourself here
Maxted
Mpg
Post by Maxted » Fri Mar 15, 2019 6:05 pm
I have a 4motion 2ltr TDI 150bhp 5months old. My long term mpg is below 40. My journey to work mpg is 40 whereas in my Mercedes c class estate 205bhp I was getting 50 mpg and on long runs 54 against 42 with the Tiguan. I was wondering if others experience similar returns as I was expecting higher. I drive in eco mode.
PBB3
Re: Mpg
Post by PBB3 » Sat Mar 16, 2019 7:56 pm
Hi I have 2017 SE 2 wheel drive 19000 miles . Motorway on Cruise Control at 70 mph
I get 56/57 mpg. At 60mph I regularly get 62/64 mpg
traveling in Spain last year on a hot day between Zaragoza & Pamplona on the AP-15 with cruise control at 50mph
67.8 mpg .
Build week 18 :D
My Car
Tiguan SWB SE Nav 2.0 TDI 2WD 150PS 7-Speed
Dark Moss Green Metallic
Winter Pack Front Heated Seats
Adaptive Cruise
Door Sill Trim Black & Silver
Park Assite with Rear view Camara.
Service Plan
5 Year extended Warranty
PBB3
Re: Mpg
Post by PBB3 » Sat Mar 16, 2019 7:58 pm
In Spain I was useing very cheap supermarket fuel. In the uk Shell or BP standard fuel
Build week 18 :D
My Car
Adaptive Cruise
Service Plan
andypj
Re: Mpg
Post by andypj » Sun Mar 17, 2019 8:56 am
I’ve had my 150 tdi 4 motion dsg RLine for 3 months now, I’ve done 3,400 miles and i have to say when i first got it, i was only getting about 39mpg on average (calculated by actual fill up rather than what the computer says), but it has gradually crept up, my last top up worked out at 46.8mpg. I fully expect this to continue to improve and am hoping to get an average of around 50mpg.
I mainly drive in either eco or normal mode, with stop start turned OFF, speed limiter set so it will go into coast mode on A/B roads and sometimes ACC on motorways and dual carriageways. I only use sport when i want to make progress. I also run the RLine tyres at 36psi for a better ride which will slightly decrease the mpg. The best I’ve seen was 53mpg over a 43 mile journey not going over 60 mph (on the way to work).
It’s impossible to compare what others are getting to either yours or mine, there are so many factors to take into consideration, from how you run it in (like you stole it or driving miss daisy) driving style, location and topography, model configuration and wheel tyre size/width, driving mode, traffic and weather conditions. What i will say is pre wltp cars are likely to have optimistic computer readouts in my experience, by about 10% or more, whereas the new Tigs have pretty accurate computer readouts, my last fill up said 47.6mpg since fill up and the actual was 46.8mpg. The other important thing to remember, the Tiguan is high off the road which makes a huge difference and it’s not that aerodynamic.
White R Line DSG 4motion 150 tdi, areaview, dynaudio, keyless & electric boot.
Collected 28/11/18 :D
F2paul
Re: Mpg
Post by F2paul » Sun Mar 17, 2019 2:57 pm
My MPG has improved with Milage , also my 20k service seems to have helped , as you would hope.
2.0 Tdi , DSG , SEL 4 motion Indium Grey. Collected 31.1.18
Return to “Introductions”
