Parking Sensors
Russ123
Parking Sensors
Post by Russ123 » Tue Jun 30, 2020 8:58 pm
Could anyone help me or share thier parking sensors settings please ?
I find there is a bit of a delay of them to activate on the front and when they do come they start off being loud then go quieter ?
I have looked at the settings and i have all tones and volume set at max. I also have entertainment fade on , but i do not know how to turn it off too as its not highlighted and it skips past .
Thank You
thejanners
Re: Parking Sensors
Post by thejanners » Wed Jul 01, 2020 4:07 pm
Thank You
Hear are my settings
Tungsten Silver R-Line Tech 2.0 DSG Petrol 230 BHP
Russ123
Re: Parking Sensors
Post by Russ123 » Wed Jul 01, 2020 5:26 pm
Thank you . Does your bleeping start loud then go quieter ?. Also how do i adjust entertainment fading as it will not allow me ??
Djhannan
Re: Parking Sensors
Post by Djhannan » Thu Jul 02, 2020 10:30 am
My bleeping is always the same volume, but more often as i get close to something
Current - ‘67 reg Tiguan R Line 2.0 TDI DSG, White, keyless start and electric tailgate
On Order - Tiguan R Line Tech 1.5 TSI DSG, Deep Black Pearl, Leather, Discover Pro, Side Scan, Tyre Pressure Monitor, Debadge
thejanners
Re: Parking Sensors
Post by thejanners » Thu Jul 02, 2020 10:47 am
Volume stays the same until you are very close and then a continuous tone with yellow and red marks in the display
The entertainment level should be able to be adjusted - I'll try mine this evening and post back
Blackstar
Re: Parking Sensors
Post by Blackstar » Thu Jul 02, 2020 10:59 am
I find having the tone set differently for front and rear very handy when close manoeuvring in a tight parking space for example or near low bollards.
2019 2.0 TDI (190 ps) SEL SCR 4MOTION DSG Atlantic Blue metallic swivelling towbar
Russ123
Re: Parking Sensors
Post by Russ123 » Fri Jul 03, 2020 2:02 am
I wonder why mine go quieter then ? Could it be different on an Allspace ?
thejanners
Re: Parking Sensors
Post by thejanners » Fri Jul 03, 2020 5:56 am
OK, the entertainment setting is adjusted by tapping the on the display (for entertainment) and moving the slider up or down.
All this does though is to reduce the sound level of the radio unit when reversing so the tones can be heard
happymal
Contact:
Re: Parking Sensors
Post by happymal » Fri Jul 03, 2020 7:14 am
[/quote]
I have the front and rear set at different tones and I have the sound turned completely down (Sound Off) when reversing, .... personal preference.
2018 Tiguan SEL 2.0TDi 150 DSG 4Motion Indium Grey with Keyless and Electric Tailgate. :D
+Passat 2.0TDi 150 DSG SE Business Harvard Blue.
:D
CNC
Re: Parking Sensors
Post by CNC » Fri Jul 03, 2020 9:00 am
Thank You
There was a change from 2019 MY onwards where the rear speakers were no longer used for the parking sensors sounds, I suspect this is why your entertainment fade is greyed out and not available so I suspect you have a 2019 MY or newer model?.
It really helps if you enter your car specification to identify differences between models and build years, perhaps you would consider adding your spec as I have below for mine.
You can read the 2019 MY changes here viewtopic.php?f=8&t=3990
I also remember reading somewhere the rear Allspace speakers are set up differently to the standard Tiguan presumably due to the extra positioning of front seat to rear most seat distance.
2018 MY SEL 150 TDI DSG 2Motion in Caribbean Blue with reversing camera & park assist plus fully debadged
