Panoramic sunroof
mrew42
Re: Panoramic sunroof
Post by mrew42 » Tue Apr 06, 2021 9:34 am
xtrailman wrote:
Tue Apr 06, 2021 8:51 am
It wouldn't bother me if my next car had no sunroof, and I certainly would be paying around a grand for one.
Me either. Never been a selling point for me. I just happen to have one on my Lease car as it "came with it". Wouldn't miss it
Newtigman
Post by Newtigman » Sat May 01, 2021 5:39 am
ExAudiSi wrote:
Sat Apr 03, 2021 10:10 pm
..... I've removed the spider traps and use Gummi Pflege to keep the seals in good condition.
What/where are the spider traps? Should I be putting Gummi P’ on all the rubber door seals too? Thanks
Micalee
Post by Micalee » Sat May 01, 2021 5:59 am
This explains all -
Newtigman
Post by Newtigman » Sat May 01, 2021 6:20 am
Brilliant. That’s really helpful. Thank you.
Micalee
Post by Micalee » Sat May 01, 2021 7:17 am
It's a job on my list :D
Newtigman
Post by Newtigman » Sat May 01, 2021 7:31 am
I’m collecting my brand new Tig later today. Should I ask them to remove these before I get there?
John27
Post by John27 » Sat May 01, 2021 9:13 am
I agree, ask them to remove the spider traps but I'd also ask them to test that the drain tubes are clear and are draining correctly (my first Mk2 Tig had both front drain tubes installed with kinks which pretty much blocked them and so the roof leaked).
Good luck with your new Tig.
Gollycrush
Post by Gollycrush » Sat May 01, 2021 12:16 pm
Good find & video & completely understand the problem of the drain pipes clogging....
But is there another reason for the "spider traps" I wonder 🤔
If its a known fault & Continue to produce vehicles with the end caps fitted, surely there must be a reason for them 🤔
I've probably overthought this 🤐🤐 but might the uncapped drainpipes let hot air from the engine bay up the pipes to the outer seal in the roof thus creating condensation up there.......similar to how unvented headlights condensate up. Just a thought 🤐🤐
PS....I don't feel so bad at not having one now
Tiguan R 320hp March 2021. Lapiz Blue metallic
xtrailman
Post by xtrailman » Sat May 01, 2021 3:09 pm
Perhaps they just keep Spiders out.
2019 SEL 190ps diesel.
Rich-O
Post by Rich-O » Sun May 02, 2021 9:11 am
No issues with panoramic sunroof on mine. VW did not install spider traps / end caps on the front sunroof drains my R-Line Tech located in the scuttle. It is easy to check they are draining ok with a jug of water. Use the sunroof regularly and is one of my favourite items on the car - would personally always go for a car with one - now issue resolved.
R-Line Tech TSI 230 4-Motion DSG - Indium Grey, Leather, Side Scan
