Does anyone know if you can split the OBD port into two, I have the carnet currently plugged into the OBD port for my 2019 Tiguan, the 2018 version did not have this as it was built in but for some reason my 2019 has the carnet plugged into the OBD port.
Now i have just seen that Blackvue offer a OBD power adaptor where you can use the OBD port to power the system but it also have the advantage of having all setting you get on the power magic available.
https://www.blackvue.uk/collections/product-page/products/power-magic-ez
So if you want to turn off the power to the cameras if you are storing the car for a few days whilst going on holiday it will stop recording when not needed, the other version you have to hide somewhere and also power via the fuse box, plugging into the OBD port means no wiring of the fuse box required and all you have to deal with is running the cables.
But can you split the OBD port like this, i have seen splitters on Amazon for around 9 pounds but will it work?
