21 - 27 of 27 Posts
I have found you on the internet looking for a solution to my problem. I tell you, I have made the change of halogen headlights to full LED headlights and in any case you have to change wiring, change pins and install a switchboard. I can provide you all the information (in Spanish). Everything works (low light, intermittent and drl) but not high light, nor DLA nor AFS curve light. As I understand it is necessary to reprogram the new switchboard that needs to be installed.
I keep you informed.
Greetings from Spain
Hello JalberT, can you please provide the information for the headlights I would appreciate it!
Hi Guys , i did the same. i upgrade halogen to Full Led. and i did all new wiring as original diagram wiring, I put the "module cornering lights" with all can-bus lines connected and now I have the same problem to programming. Some one can help ? i use VCDS. Regards
21 - 27 of 27 Posts
